1987 Ford Escort
STEVEHOWARD1969
1987 Ford Escort
Whe my engine is hot my exhaust emits black smoke, my oil level is dropping slowly so i know im burning it but where should i start to look for the problem?
Jan 2, 2010 at 6:18 PM
DAVE H
  • 13,383 POSTS
check cylinder compression .. check for leaking valve seals .. leaking piston rings etc.
Jan 3, 2010 at 12:44 AM
STEVEHOWARD1969
Thanks Dave, it's actually not a Ford Escort but an Ingersoll Rand ground compactor! The symtoms and the solutions should be the same though! Once again, thanks for your help.
Jan 3, 2010 at 11:56 AM
