1985 Ford Escort Starter Problems
CHRIS28348
Electrical problem
1985 Ford Escort 4 cyl Two Wheel Drive Automatic
Change starter and relay switch but still no engage to flywheel and the teeth is all intact. Can you help me? Also can ground play a part in not starting?
Thanks Chris
Aug 29, 2008 at 12:19 AM
BMRFIXIT
  • 19,053 POSTS
If starter engage and spins (all electric and ground OK )
but will not make contact with the flywheel to spin the engine (flywheel is good )
I would say check the starter make sure u have the right one for the right mode engine and year
check if mounted on and its all the way in where it suppose to be
Aug 30, 2008 at 10:58 PM
