1983 Ford Escort Axle Seal
69,085 MILES • 4 CYL • FWD • MANUAL
RODEOANCHOR
I am working on replacing the driver side axle seal, the problem that I am having is that I can't remove the axle. On all other types of cars that I have worked on all you need to do is put a pry bar between the transmission and the axle and pry out. I was wondering if there is a special way to do it on this type of vehicle or is it just really stuck. thanks for your time. Brad
Jan 27, 2009 at 10:16 AM
ZACKMAN
  • 4,202 POSTS
Pry bar is all you need. It is probably just stuck.
Jan 27, 2009 at 4:53 PM
