internal hissing noise, front drivers side
FORD ESCAPE
JTRLAW
Ford Escape, 1991, automatic, 60,000km
inconsistent hissing noise, like air escaping, apparently from around the pedals. Heard only at low speeds, seems to start first pressof brake pedal but if nosie exists, stops with the slighest pressure on brake pedal?
Nov 28, 2007 at 8:43 AM
  • 31,937 POSTS
Hi there,
it sounds like your brake booster is failing, the noise is vacuum leaking out the rear seal as you apply the brakes, the booster will have to be o/hauled or replaced.
Mark (mhpautos)
Mar 12, 2021 at 2:46 AM
