Bucking while driving when hot
220,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
ROBCHILDS8
Vehicle started bucking while driving, but not until the vehicle is hot. It runs fine for about 10-15 miles, then when the engine heats up, it will start bucking. Every time the vehicle bucks, I can hear what sounds like a relay clicking under the dashboard. There is no check engine light on, and all fluids are full. Any help pointing me in the right direction to repair this would be greatly appreciated. I don’t have the money to pay a mechanic at the moment, but I have tools, and enough money to buy parts. Thanks!
Jun 16, 2022 at 6:47 AM
  • 55,746 POSTS
Good to hear, let's fix it. The relay you hear clicking can be a clue to the problem, but I would like to scan for codes because an engine misfire can cause the problem as well. Are the spark plugs etc., fairly new? I have seen ignition coils go out as well. Anyway, sometimes a code will not be set if the problem has just started. Let's follow these guides and I have included the SJB (smart junction box - BCM) that I think might be the problem if everything checks out. These go out a lot.
and
This guide can tell if the SJB is going bad.
Jun 17, 2022 at 4:55 AM
ROBCHILDS8
I initially thought it might be the coils as well, but I ran a code scan on it a couple of months ago when the problem first started, and the only thing that was in there was an old code for a transmission range sensor. I did notice something new yesterday, right after I posted my question on here. Every time it lunges, and I hear that relay clicking sound, the gear indicator quickly switches from Drive to Reverse, then it switches back to Drive right away. I tried to look for this symptom before, but I think I just never caught it as my attention was on the road and not the gear indicator. I’ll run a code scan on it again tomorrow, but now that I noticed the gear selection switching back and forth, i am back to thinking it might be that transmission range sensor. Am I on the right track? Thank you very much!
Jun 17, 2022 at 9:47 AM
  • 55,746 POSTS
Yes, we need the scan. I don't think it is the range sensor.
Jun 18, 2022 at 1:51 AM
