2008 Ford Escape gear ratio
2008 FORD ESCAPE
16 MILES • 6 CYL • 4WD • AUTOMATIC
MEGASCAPE
I am building a an off-road rally rig out of a 2008 Escape. I have completed the suspension and would like to place 31" A/T's on it. I am unclear if the 31" tires will damage or place too much stress on the engine and tranny with the stock gear ratio:
First Gear Ratio (:1)2.89Second Gear Ratio (:1)1.57Third Gear Ratio (:1)1.00Fourth Gear Ratio (:1)0.70Fifth Gear Ratio (:1) Sixth Gear Ratio (:1) Reverse Ratio (:1)2.31Clutch Size (in) Final Drive Axle Ratio (:1)2.93Transfer Case Gear Ratio (:1), High1.0Transfer Case Gear Ratio (:1), Thnaks
I replaced the rear shock brackets and spaces with Willys brackets and spacers, this allowed me to place a set of Rancho RS 9000 for the rear suspension. I had a custom set of Carrera struts made that meet the valving specs of the Rancho 5000 for the front suspension. Now it's all about what is the largest tire without depleting power and creating too much power train stress.
thanks in advance,
Phil[img:a8c3f0d4d9]http://www.2carpros.com/forum/automotive_pictures/504087_OlympicPenninsulabonjonpass005_1.jpg[/img:a8c3f0d4d9]
Mar 20, 2010 at 11:53 AM
RACEFAN966
  • 5,029 POSTS
OK out of all the info you gave me which is great the one I need most is the tire size or more importantly the tire diameter of the tires that it came with. I know that the 31's are 31 inch diameter so that isn't needed. Thanks.
Mar 22, 2010 at 2:17 AM
MEGASCAPE
it came with P35/70/R16
i hope that helps and thanks.
Phil
Mar 22, 2010 at 10:50 AM
RACEFAN966
  • 5,029 POSTS
Ok you should have a P235/70-R17 stock tire size. This tire is 29.95 inches in diameter. So to go to a 31 inch tire diameter will be no problem at all.
Mar 23, 2010 at 2:55 AM
MEGASCAPE
You guys are great. i'll donate anytime to get a quick response like that..
Mar 23, 2010 at 10:46 AM
RACEFAN966
  • 5,029 POSTS
Thank you and you are also welcome. If you have anything else I can help with just ask. You have a great day. Thanks again.
Mar 24, 2010 at 3:14 AM
