2007 Ford Escape Stop Safely Now
62,576 MILES • 4 CYL • 2WD • AUTOMATIC
A2ZES
I have problem with my 2006 Ford Escape Hybrid it stall and disply this message: Stop Safely Now when we checked it using Diagnostic mach we get this Trouple Code: P0A27 what could be the problem
Sep 19, 2010 at 8:37 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
There is no defined result for this code, i have done some research and others that have had this come up have found a main battery connection and voltage problem to blame others have still to find any fault. i do believe Ford are working on this problem, some insiders are leaning towards a fault with the software in the electronics that triggers this code, i would contact Ford and see if there are any new developments, i have no technical information to support any theory as yet, i feel Ford will be the best option for you just now.
mark (mhpautos)
Sep 19, 2010 at 10:10 PM
