2007 Ford Escape Stop Safely Now
A2ZES
  • 2007 FORD ESCAPE
  • 4 CYL
  • 62,576 MILES
I have problem with my 2006 Ford Escape Hybrid it stall and disply this message: Stop Safely Now when we checked it using Diagnostic mach we get this Trouple Code: P0A27 what could be the problem
Sunday, September 19th, 2010 AT 3:37 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
There is no defined result for this code, I have done some research and others that have had this come up have found a main battery connection and voltage problem to blame others have still to find any fault. I do believe Ford are working on this problem, some insiders are leaning towards a fault with the software in the electronics that triggers this code, I would contact Ford and see if there are any new developments, I have no technical information to support any theory as yet, I feel Ford will be the best option for you just now.
Mark (mhpautos)
Monday, September 20th, 2010 AT 5:10 AM
