2006 Ford Escape has no drive in any gears ,until it cools
BUBBA390
Transmission problem
2006 Ford Escape 6 cyl All Wheel Drive Automatic 104700 kms
the overdrive light flashed and just stopped moving letting engine act like it was in neutral ,but after it sat, would move ,forward and reverse .trans fluid full, and wondered if screen plugged or a sensor might be reading false signal thanks sorry i posted wrong miles in fact KMs as Canadian eh
Oct 13, 2008 at 7:02 AM
MERLIN2021
  • 17,250 POSTS
10,000 miles? is that right? This should be a warranty problem for Ford? Upshifts are controlled by the PCM, Several things inclunding clutches, fluid, pump and TCM can be at fault, is the check engine light on? Scanning for codes is always the first step.
First thing you need to do is have the codes read, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the converter...service it right away!
Oct 13, 2008 at 7:43 AM
