2006 Ford Escape condensation leak
RICH2016
Air Conditioning problem
2006 Ford Escape 4 cyl Two Wheel Drive Automatic
I am getting water leaking on passenger side of this car when A/C is on. (no anti freeze smell). Where is the drain located? I may have a blockage.
Tnx,
Rich
Aug 11, 2010 at 2:22 AM
  • 110,246 POSTS
Rich:
It sounds like you have a blocked drain for the AC. Under the hood on the firewall (passanger side) you should see a rubber hose facing the road. Check to see if it is plugged.
Let me know what you find.
Aug 24, 2010 at 2:51 PM
