Oil Pressure Light
100,500 MILES • 6 CYL • 2WD • AUTOMATIC
JOSEPHHGRAY
After a trip yesterday that ran about 300 miles, my oil pressure light came on when I got back to town. We just bought it a couple of months ago and this is the first lengthy trip it has been on. We are under the impression that it has always gotten 5W20 oil. Do you have any suggestions? Would it help if I switched to 5W30 High Mileage oil and put in some oil treatment also?
May 24, 2010 at 1:13 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch.If abnormal could mean oil pump and/or engine bearing.
May 24, 2010 at 1:09 PM
CRAZYDEGO
My oil light flickers at idle and after 20 min of driving , but my oil is full and always maintained at every 3,000 miles, its a 2001 ford escape with 103,000 well kept
Mar 29, 2019 at 7:33 AM (Merged)
CJ MEDEVAC
  • 11,000 POSTS
It is probably time for an oil change here is a guide to help you get the job done.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Next I would do the sender. If the oil is new or has being changed then i would plan on removing the oil pan and cleaning out the oil pump pick up becasue it has been plugged with gunk.
If you are experiencing funny noises or knocking at low pressure for sure, it is probably serious! Something you did mentioned here, is have you checked your oil level. It is important to check it at minimum, "weekly" as probably prescribed in your owner’s manual and also if you suspect a problem or your gauge or light says you have a problem! Anything could happen within seconds, your oil plug falls out (installed wrong) or road debris knocks a hole in your pan! If oil is the issue, immediately shut it down!!!....no limping it another 500 feet! Remove your oil pressure sender and install a mechanical oil pressure gauge. This will give you a real accurate reading as to what your actual oil pressure is, and is doing while being driven.
A gauge set up sort a like mine, or an aftermarket under the dash mount (used as a portable, temporary test platform) will allow it to be run out from under the hood and into your window, so you can watch it as you drive, on top of the dash, or in the seat beside you.....might pick out a pertty one, you may want to mount it permanently and do away with the electric one,
Most likely your sender is defective (normally the problem in cases like yours)--- the actual gauge in the dash would be the second guess as to being bad, or the wiring in between. Some people just change the sender as their "test", that is fine, unless it does not seem to work out
I was told that 4 psi was adequate pressure to lube an engine, by a local production engine re-builder (i would not want that myself!) the norm is between 20-60 psi. 10 psi is when I start getting alert and ready to rebuild.
A "high volume" oil pump is available for my engine (may be able to find one for yours too) I have installed several on this and others I have owned previously. They have increased my pressure, and cost about $120 or so, just a guess, i gained maybe another 60,000 miles, before pressure dropped off again.
This may be an option for you, if the mechanical gauge does prove that you do have wear and tear, and pressure just ain't gonna improve until you do something mechanical. High volume pump/ internal bearings/ or a rebuild
be sure you keep us posted...we like hearing a good ending!
the medic
  • 31,937 POSTS
Check the engine oil pressure with a mechanical gauge, if it is ok, replace the sender. I have seen oil pump inlet screens plug up causing low oil pressure as well.
FANDANGO123
I have what may be two problems, but may be related.
Last week while driving around, we noticed that the oil light was coming on, or flickering when stopped at lights or idling. We took it in and they claimed it was the oil pan (It was leaking a lot, someone had stripped the drain plug) and replaced it. This has fixed the leak, but not the oil light, it still flickers or comes on at idle, mostly when the engine is at operating temp.
Second problem is that last night the check engine light came on. It had thrown the code P1506 (Idle air control over speed) It does seem to be idling high, about 1000-1400 RPM.
I'm waiting to hear back from the mechanic my wife took it to, to see if they actually did an oil pressure test. I don't have a guage, but am thinking that if the pressure is okay it is likely a bad sensor. But we are on a very tight budget right now, and any insight anyone here can offer would be greatly appreciate. I'd love to hear what everyone thinks and if anyone has had this combination of problems before.
  • 110,248 POSTS
I have to be honest, the idle issue is most likely the idle air control valve (IAC) or a vacuum leak. If the idle was really low, the I would say the IAC and the oil light could be related. However, that isn't the case. Tell me, do you hear any ticking or knocking from the engine when the light flickers? The engine has a lot of miles on it, but if it has been maintained, it should be okay. If there is no noise from the engine, my guess is the sensor, as you mentioned.
FANDANGO123
Thanks for the reply. No knock or tapping, which is a huge relief to me. Oddly enough, the idle did seem low(but smooth) to me before the code was thrown. And I wondered if that was the problem. Now it is idling high, the light is barely on. But it does come on sometimes, which is enough to make me think it is not just a low idle problem,
  • 110,248 POSTS
The only way to be 100% sure is to check the oil pressure using a mechanical gauge. Most parts stores will lend you one. Basically, you remove the electric pressure sensor and screw in the mechanical gauge. That way you will know what the actual pressure is at idle and when the light would normally flicker. As I mentioned, since there is no noise from the engine, I agree with you that it is most likely a sensor issue. But to be sure, you need to check the actual pressure.
Let me know if I can help in any way.
FANDANGO123
Sounds like a plan. Do you happen to know if I can get to it without removing the AC compressor?
  • 110,248 POSTS
Sorry I didn't get back to you sooner. You should be able to get it from under the vehicle. If you have access to a lift, it would make life MUCH easier.
WYATT_EARP5
I driving with my GF last night in her Escape XLT (2001 - V6 and about 80K) and all of a sudden the engine revved up (RPMs were about 5500-6000) as if she was in a lower gear all of a sudden. I told her immediately to shut it down as I thought the motor was going to blow. Well at this point the motor was running at almost an idle until it completely stalled. The oil light was the only light that came on until the truck completely died then all the typical lights came on. We tried to start it and it would so long as you kept gas on it as it would not idle itself. I asked her about when she last checked or changed the oil. Well it has been a year for both. It was dark and no flash light but i did my best to check the oil. Anyway I dumped 3qts of oil in it (thinking it was out or extremely low) and got it home but had to power brake it all the way to keep it running. The oil light flickered here and there for the short drive home and as I was driving it in the parking lot at home I kept the windows down to listen for a knocking/dieseling and I did hear it doing just that.
Thoughts anyone? Oil pump? Sending unit (sensor?). I am not a mechanic but I can do a lot of things if I have an idea of what to do. So any help would be appreciated. and thank you in advance.
Tim
2CARPRO JACK
  • 11,533 POSTS
If you say the engine is knocking, then it might have had a low/no oil condition, causing bearing damage.Tearing down the engine is the only real way to see the extent of the damage.The stalling, will need to have the PCM scanned first for trouble codes, this may lead us in the right direction for a fix on that problem
ASDUBBIN
Oil light flickers at idle in Drive at 700rpm when you accelerate light extinguishiers. any ideas and where is the oil pressure switch located
rgds
DOCFIXIT
  • 18,828 POSTS
Switch on left front engine when out check pressure with mechanical gague
