2005 Ford Escape MOANING/GRINDING NOISE
11,000 MILES • 6 CYL • FWD • AUTOMATIC
MJCFEB58
When my truck is cold, the front wheels make a moaning/grinding sound when turning right or left. Seems to go away when everything is warmed up (tires/engine) My brakes have 10k miles on them, as do my tires. What could be the cause?
Oct 15, 2010 at 2:29 PM
STUART BROWN
My 2005 Ford Escape had similar sounds when cold. The dealer was familiar with the problem and immediately replaced the front shock upper bearings in the tops of the shock towers. Apparently these bearings seize up and resist any turning motion of the shock struts when the suspension deflects or steering input occurs. Repair result - noise gone! The same noises are showing up in my 2007 Ford Freestyle - the dealer will replace those shock strut bearings soon, too. Hope this helps!
Dec 25, 2010 at 11:16 AM
