Engine keeps using coolant
JIMBOSGT6
  • 2005 FORD ESCAPE
Engine Cooling problem 6 cyl All Wheel Drive Automatic 51000 miles
Recently, the Ford Escape is using engine coolant. In the last 2000 miles, I have put in about 3 quarts of coolant. There are no signs of any leaks. All of the hoses and the radiator are dry. There has never been any leakage of the garage floor.
The oil level is normal and shows no sign of contaminaion with coolant.
There are no signs of white smoke from the exhaust and the tail pipe is normal in color.
Could it be a intake gasket that is leaking?
Wednesday, August 20th, 2008 AT 12:27 PM
BMRFIXIT
  • 19,053 POSTS
You need to have the system pressure tested
Here is a guide to help
https://www.2carpros.com/articles/car-is-leaking-coolant
Tuesday, August 26th, 2008 AT 6:29 AM
TANK5874
  • 2002 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • 200,000 MILES
I am having to add engine coolant or water every day but is not running hot. What is the problem? Why am I having to keep adding every day? I cannot find any visible leaks.
Wednesday, November 1st, 2017 AT 7:00 PM (Merged)
  • 31,937 POSTS
You will have to get a cooling system pressure test done to help locate any external leaks. Do not allow coolant to run low as you will over heat and damage the engine. You may have to get the car on a hoist to locate any leak, it may be small and evaporating but if left unattended it will get worse, so act on this ASAP.
CHRIS61
  • FORD ESCAPE
I have a 2001 Ford Escape with 81,000 miles on it. For some reason, it loses about 10 oz.S of water every 5 weeks or so. Enough to make the low coolant light go on. I tried changing the cap to the overflow tank with no luck. There are no leaks that I can see in the coolant system and no drips in the driveway. Also, no white smoke coming out of the tail pipe. There is the smell of hot coolant under the hood though which was why I changed the cap. No check engine lights or anything either. Both electric fans come on when it gets hot. Any ideas?
Thursday, November 2nd, 2017 AT 9:49 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
If you smell it, the coolant is probably burning off before you see a drip or leak. Look for traces of dried coolant around areas that got hot like the manifold.
MATHIASO
  • 1,209 POSTS
You problably have an extern leak that evaporate before you can see it.
You may need to use a pressure tester to pump the system to the rated pressure while observing the external cooling system components for any signs of leak.
GREGGESCAPE
  • 2002 FORD ESCAPE
  • 3.0L
  • V6
  • 4WD
  • 150,000 MILES
I have replaced the leaking coolant overflow tank in my 2002 ford escape but when I ran the engine to allow for the fluid to adjust there was no change in the level of coolant in the overflow tank. After letting the engine cool, I started it again and ran it with heater on high. The engine is still running hot.
  • 110,055 POSTS
Have you replaced the thermostat? Are the cooling fans working? Does it only overheat when it is in traffic or at highway speed too?
