Its an 05 with a 2.3 motor. it is not a hybrid. It started off not wanting to idle directly after getting off the expressway. Then it got worse and wont idle in gear except for after first start up when it is still warming up. It will idle if i give it a little bit of gas or put it it neutral. In gear drive or reverse it stalls. Runs fine otherwise. It sounds like an idle air bypass valve which i had go bad on another car so i changed it. No real change although i didnt clear the cpu. There is no check engine light and i dont have acess to a code scanner. any ideas before i tear into it later today? thanks
Dec 20, 2007 at 12:42 AM
