2005 Ford Escape abs
75,453 MILES • 6 CYL • 4WD • AUTOMATIC
AASFORD
  • 9 POSTS
The abs light stays on and the 4x4 light flashes on and off. It go's off for a while then the 4x4 flashes again.
Oct 23, 2009 at 1:17 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will need to get a scan done as there will be unresolved fault codes in the ECU, this is what the lights are telling us.... when you have the codes, check with your own service dept, or re post her for further information as there is not much i can tell you with out knowing what code is set.
Mark (mhpautos)
Oct 23, 2009 at 7:05 PM
