2004 Ford Escape engine overheat
ARROWAN
Engine Cooling problem
2004 Ford Escape 4 cyl Two Wheel Drive Automatic 65k miles
water spills off from the water reservoir even just a short distance of travel. Radiator fans are working and water pump is not showing any symptoms of troubles. Thanks.
Jul 11, 2010 at 11:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
remove and test the thermostat , it may be stuck preventing coolant flow
Sep 30, 2010 at 8:41 AM
