2004 Ford Escape 04 Ford Escape Misfire code in #5 cylinder
KMS9827
  • 2004 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 85,000 MILES
I have a 2004 Ford Escape XLT, 3.0 L V-6 with 85k miles on it. A few weeks ago, while raining, the car began to sputter and the check engine light came on. I parked the car, and the next day when it was dry, it ran perfectly with no check engine light. A few days ago, it began sputtering again, the check engine light came back on, and the car had poor acceleration, almost coming to a stop when going up hills. I ran the diagnostics and came up with a P0305 code, indicating a misfire in cylinder #5. I also received a code telling me there was excess fuel in my exhaust (which coincides with a misfire). I replaced ALL of the spark plugs, and still had the same problem. I then replaced the Coil on the #5 cylinder. After replacing both the plug and coil in cylinder #5, I am still getting a misfire code for cylinder #5, the spark plug in cylinder 5 smells like gasoline, which tells me that it isn't making a spark, and I can hear a loud "clicking" noise coming from around the coils. Would this be a wiring harness problem?
Monday, March 29th, 2010 AT 3:22 PM
  • 110,182 POSTS
Have you checked the plug in that cylender to see if it getting spark? Also, try this. In the dark, start the car and open the hood to see if there is arcing near that coil / cylender. Mist some water on the electrical components to see if that makes it worse or creates an arc.
Let me know what you find.
Tuesday, May 4th, 2010 AT 1:43 PM
KMS9827
OK, the plugs (both the old one and the new one) in cylinder 5 are not sparking. When I spray water over the coil, the engine sounds like it is going to stall. The COP is brand new, which is pointing me back to a wiring problem. I heard from a Ford mechanic that 2004 Escapes are known to have a problem with the wiring harness coming from the PCM to the COP's corroding or even breaking inside the insulation. Does that sound plausible?
Thursday, August 26th, 2010 AT 11:55 AM
  • 110,182 POSTS
Yes that is very possible. Have you checked it?
Thursday, August 26th, 2010 AT 8:54 PM
ESCAPE OWNER
  • 11 POSTS
I had the same problem and it leads to clogged Cats. The misfiring sends unburned fuel into the Catalytic Converter thereby clogging it. This is a common problem with Escapes. Don't drive it when misfiring and get the problem fixed.
Thursday, March 24th, 2011 AT 6:30 AM
TALON747
Were you able to find the bad wiring? I am having a similar problem.
Monday, November 7th, 2016 AT 10:56 AM
