Engine shuts down
192,033 MILES • 3.0L • V6 • 2WD • AUTOMATIC
GIGISULAMANIDZE1
  • 88 POSTS
The engine cuts out while driving 20 mph. It happens three or four times a week. The engine does not start easily either. When the car is running it is fine, no noticeable problems, no misses, plenty of power. Sometimes when I turn it off it will not start. After five minutes it starts like nothing happened. New coils, new sparks, throttle cleaned, idle control valve cleaned.
Sep 27, 2018 at 7:07 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I suspect your fuel pump may be weak/failing. Best thing to do is perform a fuel pressure test. If you do not have access to a tester your local auto parts stores have a loaner program and will rent you one. It attaches to the Schrader valve on the fuel rail. With the key on engine off the system should be 35-65 P.S.I. I have attached a tutorial showing what is involved for the testing procedure. Hope this helps and feel free to ask any questions if needed.Thanks for using 2CarPros.
Danny-
Sep 27, 2018 at 7:22 PM
GIGISULAMANIDZE1
  • 88 POSTS
Hi, fuel pressure was good, I have changed fuel filter, spark plugs coils cleaned throttle body I use FORSCAN no trouble codes today. Turned off at 40 mph. Usually it turns off when I get off leg from gas pedal.
Nov 5, 2018 at 3:27 AM
  • 55,758 POSTS
This sounds like a typical crankshaft angle sensor going out which will not trigger and trouble code. Here is a guide to walk you through the steps and the location of the sensor on your car below:
Cheers, Ken
Nov 8, 2018 at 3:59 AM
GIGISULAMANIDZE1
  • 88 POSTS
I fixed problem two days ago. It was crankshaft sensor.
Nov 8, 2018 at 4:01 AM
  • 55,758 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Nov 9, 2018 at 2:45 AM
JLMTCH
On occasion, while in reverse, it's as if my battery stops sending power to the car, it stalls, and my oil and battery light come on. I put the car in park, turn it off, start it back up and it runs fine.
Nov 9, 2018 at 2:46 AM (Merged)
WRENCHTECH
  • 20,758 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
CJ MEDEVAC
  • 11,000 POSTS
My wife drives the same rig.
You can have it off, cleaned, and back on----in 30 minutes or less or the the 1st guy will bring you a pizza for free! lol
This is how EZ it is, I hope this is your problem too!
https://www.2carpros.com/questions/2005-ford-escape-rough-idle-at-low-rpm
Keep us informed
The Medic
WRENCHTECH
  • 20,758 POSTS
Please follow the advice I gave you in the first response and don't let the subsequent response confuse you. He insists on confusing people I'm working with. The throttle body and throttle plate is what I asked you to clean. You can remove the IAC also if you wish but following my instructions should get both things.
BINGOPRINCESS
My 2003 Ford Escape xlt check engine light is on. We just had the fuel pump replaced and a fuel filter. The same day as it was replaced, the check engine came on right after we got gas. My husband drove our car to NJ today and on the way home, the engine cut out. Just need to know what is wrong. Seems as soon as something is fixed, light comes again and it is something new.
Nov 9, 2018 at 2:47 AM (Merged)
RIVERMIKERAT
  • 6,106 POSTS
Your question was cut off. If the check engine light is on, you need to have it scanned for soft and hard codes.
ASCOTT3859
after engine gets hot-10 to 15 minutes driving- it just cuts off while going down the road. It will not restart
till it sits for maybe two hours. After it sits, it cranks and runs fine.
  • 110,248 POSTS
When this happens and it won't start, have you checked to see if there is spark and fuel to the engine?
ASCOTT3859
First time it stopped I had it towed.
Second time, It was left side of the road. I went back in two hours and it
started fine. I was trying to get some ideas without breaking down beside the road again. No chance to check fuel or fire.
  • 110,248 POSTS
I have to be honest, without checking for those things, I am at a stand still. I have no idea on which way to go.
