turn signal flasher?
W SOSA
where is the flasher located?
Sep 22, 2008 at 7:05 AM
  • 75,988 POSTS
The electronic flasher module is located behind lower left end of dash, where DRL module is also located at. Check out the diagrams (Below). Please let us know what happens.
Sep 22, 2008 at 7:14 AM
PAUL ALLEY
Turn signals do notwork but flashers do. I use to push in flasher and it would work. Now all of a sudden this will not work no more need. New flasher? I hope this is all it needs.
Nov 26, 2020 at 12:14 AM (Merged)
  • 110,248 POSTS
It could be the flasher has failed. However, the idea that you had to push it in place may indicate there is an issue with the electrical connectors where it mounts. Remove the flasher. Take a flashlight and check to make sure none of the connectors in the plug are pushed back inside eliminating the connection to the flasher.
If that is good, check fuse 6 in the fuse box located in the vehicle passenger compartment. I attached a picture of the box and legend. If you noticed, the reverse lights also use this fuse, so you can check if they are working. If they are, the fuse is not the problem.
Next, if everything looks good, then chances are the flasher has failed and needs replaced. Using a test light, you can confirm power to the flasher. Here is link that shows how to use one:
Let me know if you have other questions or need anything. I hope something here helps.
PAUL ALLEY
Where is the turn signal flasher or flashers located? Looked all around found where the hazards are flashing from under dash but it is not a flasher. Thanks
Good afternoon.
The flashers are not like the old type. They are relays.
I attached a picture of the location for you. They are under the left side of the dash.
They are marked A17 in the diagram.
PAUL ALLEY
Okay thanks, I will check it out again. I saw two next to each other one yellow one blue in same plastic holder. Do I cut the wires or am I replacing the part I pull it from?
MACKO
  • 10 POSTS
Do you have a part number for the flashers? Are the flashers separate from the hazard flashers?
Jan 20, 2026 at 3:59 AM
  • 55,616 POSTS
Yep, the flashers for both are in one unit. Flasher part# YL8Z-13350-AA (ford)
Jan 21, 2026 at 1:30 AM
MACKO
  • 10 POSTS
I have a replacement flasher on the way. How do I get to it? I don't fir under the dash unless I maybe take out the driver's seat
Jan 28, 2026 at 10:02 PM
  • 55,616 POSTS
it looks like it is on the driver side dash up underneath. Here is the location, match the new one up to the old unit to be sure. Check out the images (below). Let us know what you find.
Jan 29, 2026 at 1:03 AM
MACKO
  • 10 POSTS
How do you access the flasher?
Feb 2, 2026 at 2:43 AM
  • 55,616 POSTS
You need to remove the lower dash panel on the drivers side.
Feb 2, 2026 at 4:38 AM
MACKO
  • 10 POSTS
So how do I remove the lower dash panel?
Feb 2, 2026 at 5:25 AM
  • 55,616 POSTS
Sure, here are images to help you remove the lower dash panel. Check out the images (below). Please upload an image or a short video in your response, so I can see what's going on.
Feb 3, 2026 at 7:45 AM
