2003 Ford Escape Oil pan leaks
72,000 MILES • 6 CYL • 4WD • AUTOMATIC
ICEMANBS69
How do I replace my oil pan and properly seal it.
I have the new pan and new seal, but I need to know if there is anything else I need to do or add to make a proper seal.
Jul 24, 2010 at 5:08 AM
  • 110,248 POSTS
Here are the directions I was able to find for you. 1.Before servicing the vehicle, refer to the Precautions Section. 2.Drain the engine oil. 3.Remove or disconnect the following: Negative battery cable Flexible exhaust pipe Downstream catalyst monitor sensor Oil pan and gasket 4.Thoroughly clean the gasket mating surfaces. Fig. Oil pan torque sequence-3.0L engine
https://images.2carpros.com/forum/automotive_pictures/249084_5_54.jpg
To install: 1.Apply silicone sealer to the oil pan. 2.Install or connect the following: New gasket on the oil pan Oil pan. Torque the bolts in sequence to 18 ft. lbs. (25 Nm). Flexible exhaust pipe Downstream catalyst monitor sensor Negative battery cable 3.Fill the engine with clean oil. 4.Start the vehicle and check for leaks, repair if necessary. Let me know if it helps. Joe
Aug 24, 2010 at 3:07 PM
