2003 Ford Escape 2003 FORD ESCAPE CLUTCH PEDDLE TO THE FLOO
95,000 MILES • 4 CYL • FWD • MANUAL
THESCRABBLEQUEEN
My Escape has had clutch problems in the past, sometimes it shakes but tonight the peddle stuck all the way to the floor and had to be lifted with my toes and was difficult to put into gear afterwards. It had the clutch replaced from the recall a few years back. I've read about bleeding the line, and perhaps we will try that tomorrow-- any ideas on doing that correctly? I assume the clutch is bad, but it's worth checking for air first. How does air get in the lines, to begin with? Is getting a new clutch in this model super expensive?
Jul 11, 2010 at 2:41 PM
  • 31,937 POSTS
HI there,
This will be a hydraulic problem, check the fluid level, if low top up and re bleed, air can enter the system via a faulty clutch master or slave cylinder.
Mark (mhpautos)
Jul 11, 2010 at 6:30 PM
THESCRABBLEQUEEN
is the Master Cylinder. Almost $300 to repair, not as bad as we expected so I guess that's a plus! Cars can't last forever, thanks for the reply. Good luck out there folks.
Jul 13, 2010 at 3:35 AM
  • 31,937 POSTS
Hi there,
Thank you for the feed back and thank you for using 2carpros.
mark (mhpautos)
Jul 13, 2010 at 3:43 AM
