2003 Ford Escape
IRONHEADBAR3222
Engine Performance problem
2003 Ford Escape 6 cyl Four Wheel Drive Automatic
ok i have 03 ford escape and over night it will not run
you start it up and VERY ruff ideal step on the gas and it will not go i and it is not kicking a code i have no idea at all please help
Jan 7, 2009 at 4:19 AM
BMRFIXIT
  • 19,053 POSTS
check fuel
fuel pressure and fuel pump
check for vacuum leak s
Aug 12, 2020 at 6:35 AM
IRONHEADBAR3222
hey thanks i did change filter on the gas no change i think maybe cats are bad just tring to find which side is bad....thanks for your help
BMRFIXIT
  • 19,053 POSTS
do u have fuel pressure ?
if its a cat u think remove the O2 sensor before the cat that will allow it breathe
I do NOT think it is a cat but good luck
