2002 Ford Escape warning lights
122,000 MILES • 6 CYL • 4WD • AUTOMATIC
JFARMER65
I recently purchased a used 2002 Ford Escape. Within a week the battery light came on, remained on for a few minutes and went off. Since then it comes on and remains on almost constantly, I had the battery checked at a local auto parts store and was told it is fine, but my alternator is bad. However, I have had no problems with loss of power or starting??? Now, the ABS light has come on as well as the airbag light. I have an appointment with my mechanic to check out the alternator, but I am wondering if this could be a fuse or possibly a computer module issue?
Apr 26, 2010 at 2:49 AM
  • 110,248 POSTS
Chances are you have a bad alternator. If they checked it for output and it failed, that would be the problem.
May 4, 2010 at 3:36 AM
