2002 Ford Escape shut off
CHALO
  • 11 POSTS
Engine Performance problem
2002 Ford Escape 6 cyl All Wheel Drive Automatic
I Have problem like vacuum leaking, because when I start The motor everythin runing good but when I accelerate the motor shut off, and I found one of the vacuum hose become close at the elbow on the intake exit, I unplug the hose from the intake and on the front of motor but the hose is correct nothing is broken, could you help to find the leak, thanks
Nov 4, 2009 at 11:42 PM
CJ MEDEVAC
  • 11,000 POSTS
are VACUUM OK......
Nov 6, 2009 at 3:56 PM
CJ MEDEVAC
  • 11,000 POSTS
GOOD LUCK!!!
Nov 6, 2009 at 4:02 PM
CHALO
  • 11 POSTS
Well I found code P0113, IAT Sensor 1 circuit high input, are you think that is the cause of my engine stall, thanks Gonzalo
Nov 7, 2009 at 7:38 PM
CJ MEDEVAC
  • 11,000 POSTS
Looks like you are on right track
Nov 7, 2009 at 9:17 PM
CHALO
  • 11 POSTS
Do you know how much the MPC-161 because I trhink this is broken or something burning after a booster on the wrong polaryti, and that could be fix my problem for stalling motor.
Nov 17, 2009 at 11:21 AM
