Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Escape
Engine
Symptoms
Idle Rough
2002 Ford Escape rough idle
2002 FORD ESCAPE
18,800 MILES • 6 CYL • 4WD • AUTOMATIC
KIRKRAPTOR1
MEMBER
1 POST
Just replaced fuel filter,plugs,coils,boots,air filter,oil change- engine is running rough has stalled a couple of times
Nov 2, 2010 at 1:04 PM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
Nov 2, 2010 at 6:50 PM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
