2002 Ford Escape rough idle
18,800 MILES • 6 CYL • 4WD • AUTOMATIC
KIRKRAPTOR1
Just replaced fuel filter,plugs,coils,boots,air filter,oil change- engine is running rough has stalled a couple of times
Nov 2, 2010 at 1:04 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
Nov 2, 2010 at 6:50 PM
