2002 Ford Escape NEED HELP
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
BARANEKSTEVE
I started the car and it started to shake and the engine was making a odd sound and some white smoke came out the tailpipe. shut off the car, checked under the hood and everything looked ok. I checked the oil dipstick and it was almost empty, I added 3 liters of oil in which brought it up to the first mark on the dipstick. I restarted the car and the car started fine. I drove the car around the block for 5 minutes and had no problems. Then I took the car out on the road and came to a stop. When the light changed and I started up I tried to apply the gas and the car would not go more then 10 miles per hour. The check engine light flashed and then went off again. So I parked the car and I don;t know what it all means, who I should take it to and what kind of charges to expect. When I had last driven the car two days before I had had no problems and no leakeage under the car.
Dec 27, 2009 at 6:12 AM
MATHIASO
  • 1,209 POSTS
Hello BARANEKSTEVE
Have it scanned, and come back with code(s).
and recheck the oil level .Auto Zone helps people scan their vehicle for code(s) and for free.
Dec 27, 2009 at 6:52 AM
