2002 Ford Escape loss or power/egr failure
2002 FORD ESCAPE
117,000 MILES • 6 CYL • 4WD • AUTOMATIC
AGENTJEREMY
I've recently had problems with my 2002 ford escape.While driving home the other night I began to loose power and throttle response, shortly after that the egr valve body blew a hole. I replaced the egr valve and still not responding with much power or acceleration. then last night on my way home again it blew out again.Is there a filter or something that could be blocking the vacuum line that opens the egr valve that may be the cause of this problem?
Feb 2, 2010 at 5:16 AM
ESCAPE OWNER
  • 11 POSTS
Sounds like one or more Catalytic Converter is plugged. The plugging is usually caused by raw fuel. Was the engine misfireing?
This is a common problem in Escapes.
Mar 23, 2011 at 11:42 PM
