2002 Ford Escape Idles rough
121,000 MILES • 6 CYL • AWD • AUTOMATIC
SIDOL
The engine idles rough when you turn on the A/C. I have had codes in the past that said I had a multple cylinder misfire. I replaced all 6 plugs but I did not replace the coil paks. It seams to run fine until it get under the strain of the A/C. Any ideas what may be the cause?
Jun 30, 2010 at 12:08 AM
  • 110,251 POSTS
Have you checked for vacuum leaks? Does the engine run properly other than at an idle?
Jul 2, 2010 at 6:35 AM
