2002 Ford Escape fuel problem?
2002 FORD ESCAPE
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
NIBKIB
2002 ford escape...truck was running fine except the last few mornings..i would go out and start it for the first time of the days and it would have plenty of ignition but just would not start..after a few times of trying it would start..but now today it wont start at all..it still has good ignition turning but just wont start..but i did try one thing..i held the gas to the floor and it started only to stall out and white smoke came out the exhaust after i took my foot off the gas..the fuel pump starts fine and the reset switch is fine..any suggestions?
Sep 14, 2008 at 10:24 PM
  • CERTIFIED EXPERT
Check the fuel pressure to rule out a failing fuel pump and also check for injection pulses and test the coolant temperature sensor
Sep 15, 2008 at 12:45 AM
