firing order diagram
ATVRAY
Hello I need the engine ignition firing order diagram please.
Aug 10, 2009 at 3:14 AM
STEVEW84
  • 673 POSTS
firing order is 1 4 2 5 3 6.
https://images.2carpros.com/forum/automotive_pictures/170495_firing_order_escape_1.gif
Aug 10, 2009 at 3:27 AM
GLEAMON
Engine code show I need to replace the coil on the number 3 cylinder in my Escape. I do not know the firing order on this engine. Where can I go to find this out?
May 29, 2020 at 5:56 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Cylinder numbers are 1-2-3 on RH bank and 4-5-6 on LH bank.Left bank faces front of vehicle.
Firing Order 1-4-2-5-3-6
Cheers
GLEAMON
Thank you!
ZEROMAN
Which cylinder is number four? Engine is transversely mounted. I have seen several websites but not a true layout. I know Fords are numbered front to back, passenger side first, but am confused because the engine mounted sideways.
Oct 10, 2020 at 2:27 AM (Merged)
WRENCH
  • 57 POSTS
Hope this helps you.
cylinder numbering, facing your car, from left to right.
rear bank 1-2-3
front bank 4-5-6
and your firing order is
1-4-2-5-3-6
