2001 Ford Escape egr valve
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARISEL6
why does the egr valve keep blowing out, also it shakes alot when at a stop sign
Sep 27, 2010 at 4:23 AM
DOCFIXIT
  • 18,828 POSTS
Exhaust restriction will cause both conditions have back pressure tested CAT maybe particaly blocked
Sep 27, 2010 at 6:18 AM
ANONYMOUS
  • 0 POST
check engine light diagnosed related to egr and later on car will slow down while driving and start jerking whiles in motion.i have changed the solenoid valve and looks like problem is not solved fully?
Mar 22, 2017 at 11:46 AM (Merged)
RACEFAN966
  • 5,029 POSTS
Is the engine light still on? If so scan it and get the codes. Most parts stores will do a free scan. Once scanned write down the codes and then clear them and get back to me with the codes ok.
MAVIS AYORINDE OLORUNLEKE
  • 5 POSTS
Hello all, please i have similar problem but in different form. I bought my car Ford Escape 2008 V6 Limited version last year at 107k miles, but presently with 120k miles range. Recently i was declining from hill when i sudenly lose power on my accelerator and "check engine sign" showed in yellow on my dashboard with oil an battery indicator in Red. I put of the ignition and restart, to drive it home, but the check engine sign remain on the dashboard. After diagnostic scan code P0191 Fuell rail pressure sensor circuit/performance was shown and it was changes. After one week of using, it came up while was on hiighway at 120km. I was able to manage it back to the mechanic. and a routin service was carried on it. He advice i drive it for a complete cycle to see it will happen again. 3days after, its occur again (i.e the engine lose power, that accelerator was ineffective and check engine sign came up) while my wife was driving BUT this time when she put it off and re-start the engine, lo there was no check engine sign again. But has anyone experience such issues on his SUV either tribute or mazda of same model. what did you change apart from Fuel Rail Pressure Sensor? It happens again on Saturday, the check engine sign came up and engine short-off. Several attempt to restart was going of intermittently. I had to let it rest some few minute before its start. I drove it again to my mechanic and this time we planned to check fuel pump and filter. Has anyone experience this issue before? thanks for feedback.
  • 55,560 POSTS
Yes the fuel rail sensor is trying to tell you the fuel pump is going out and needs replacement, here is a guide that will show you what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Please let us know what you find so it will help others.
Best, Ken
NIKKIJ0120
Engine Performance problem
2002 Ford Escape 6 cyl Two Wheel Drive Automatic 113000 miles
what's wrong with your car when it sputters, and its not idleing right.
I went to auto zone because the check engine light was coming on and the machine told me that it was showing insufficient flow to the EGR valve.
STEVEW84
  • 673 POSTS
What you probably have wrong is what is called a Delta Pressure Feedback EGR(DPFE) Get one from the dealer only. I have seen the aftermarket sensors not work well. HTH.
https://images.2carpros.com/forum/automotive_pictures/170495_dpfe_2.jpg
JLITTLE7701
2002 Ford Escape Automatic
How do I determine if the EGR vakve us bad on a 2002 Ford Escape, 6 cylinder?
ZACKMAN
  • 4,202 POSTS
Please tell me what codes that you are getting before you replace the EGR valve. Many, and I mean many people have replaced EGR valve for the wrong reasons. And what makes you think your EGR valve needs replacing.
BILL HALL
2004 ford escape 4 wheel drive, broken EGR valve
SATURNTECH9
  • 30,869 POSTS
So how is it broken and what is your question?
GALVO1
2002 Ford Escape 6 cyl Front Wheel Drive Automatic 220000 miles
I see someone else had the same problem. any answers to as why?
GALVO1
[quote:fb81a99283="galvo1"]Engine Performance problem
I thought because of the mileage, that the EGR may have been cracked,and a hole was blown through it, so I repaced it. Within 5 miles a hole was blown in the new one. The only code I have gotten was P 0401. I was told it was most likely the catalytic converter. As it turns out, there are 3. Any one have any idea of which, or if that is even a possibility? Could there be enough heat and pressure built up if the EGR is completely closed?
I see someone else (jnoesen),had the same problem. any answers to as why?[/quote:fb81a99283]
