I have a 2002 Ford Escape with 82000 miles and I am having a recurring problem with the Check Engine Light. The light first illuminated (solid) on September 16, 2007. I took the vehicle into a Ford Service Center the following day, but they could not identify what was causing the light to come on. They reset the light and I left. Over a period of 4 weeks, I was back at Ford 6 times for the same problem (9/17, 9/24, 9/26, 10/2, 10/4, 10/9) and again on 10/9 and 11/26. Just as I would roll to a stop, the car would shudder like it was going to die, and then the check engine light would come on. Afterward, it seemed to run fine but each time I made an appointment with the Ford Service Center. It also seemed to only happen when the air conditioner was running or if we had been driving distances of more than 30 miles or so. I told the Ford center that it seemed like it only came on when the air conditioner was running and they kept telling me that it had nothing to do with the check engine light. (Maybe it doesn't but I it has only happened after the air conditioner is turn on)
The following things have been replaced/repaired: 1CYL IGN Coil & Spark Plug (9/26/07) and Idle Air Control Selinoid (12/18/07).
Two weeks ago (6/3/08), the check engine light came on again after the same shudder feeling. I went back to the Ford center and they said they are getting a code P0351. They contacted a Ford Technical Rep who gave them a Technical Service Bulletin 05-11-01 which refers to 2005 Escapes and 2005 Mariners. Among other suggestions, the bulletin says to replace all the spark plugs. They reset the light and said to drive it and see if the light comes back on.
I've driven it since and yesterday the car did the same thing - shuddered and then the light came on. I have an appointment on Thursday but am trying to find anyone who might have had a similar problem and/or solution. I'm sorry for all the detail but I just am not a "car person" so I'm not sure what information is important - thank you!!
Jun 16, 2008 at 7:21 AM
