catalytic converter is glowing red
OTISP23
Engine Mechanical problem 6 cyl Four Wheel Drive Automatic 160000 miles
from everything i've been reading this sounds like a fuel pressure regulator or a fuel injector problem, but my manual says nothing about a pressure regulator. should i just go ahead and change the injectors or is there a pressure regulator or could it possibly be something else. thanks for the input
Nov 15, 2009 at 1:08 PM
MATHIASO
  • 1,209 POSTS
hello otisp23
Check to make sure the air diverter valve is not stuck open because it sounds like it is allowing extra air into the exhaust system causing the catalytic converter to glow red hot. Check to make sure the control valve is not stuck open as well.
Here are some guides to help you see what I am talking about
Please let us know what you find.
Cheers
Nov 16, 2009 at 6:01 PM
OTISP23
per your suggestion, I have checked the fuel pressure and found the following: 65 PSI.
Looking in my Chilton Manual it shows that the PSI should be 39-55 PSI for the 2002 V6 engine. I may be thinking to hard but the sticker on the car door shows shows that it has a manufactured date of August 2001. Does that matter (manufacture date vs. model year?). If so, looking at my manual for a 2001 engine the PSI range is 35 - 65 PSI.
A little history...the car had been sitting over the summer (It had needed new spark plugs but didn't change). Battery died, didn't know for how long battery had been dead. Recharged battery car did not start, barely firing so then changed spark plugs replaced with NGK Laser Platinum plugs (PTR5f-=11 6579).
Car started with new plugs just fine (the wires are on the correct plug I changed one at a time so no chance of crossover).
Did test drive and that is when catalytic converter glowing red issue started. And barely ran. I then ran OBDII test on car computer despite no engine light being on and came up with two codes: P0172 - "System too rich (Bank I), which would explain the "glowing cat" but why is it too rich? The second code was a Tranny code P0720. Also before car was parked for summer there were no codes indicating a possible problem.
Even though the car seems like it is idling fine I checked the air diverter valve and sure enough the valve has stuck open so I replaced it and the problem is fixed.
Thanks 2carpros! you guys are great!
Nov 17, 2009 at 12:38 PM
MATHIASO
  • 1,209 POSTS
Good to hear I did run across some moe information on the problem for others that visit this post.
If there is no engine light but you pull out codes.
if there are no pending codes, then the light bulb burn out.
The code P0172 means rich, we may agree tha rich fuel has caused catalytic to glow.
the fuel pressure is normal.
The MAF (Mass Air Flow) Sensor is dirty or faulty need to be checked and cleaned.
There could be a vacuum leak.
Possible Solutions
Inspect all vacuum and PCV hoses, Clean the MAF sensor. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling Inspect fuel lines for cracks, leaks, or pinches Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced. Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
Manufacturer diagnosis
Camshaft timing is incorrect, or the engine has an oil overfill condition EVAP vapor recovery system failure (may be pulling vacuum) Fuel pressure regulator is damaged or leaking HO2S element is contaminated with alcohol or water MAF or MAP sensor values are incorrect or out-of-range One of more fuel injectors is leaking '
P-0720
OSS defective
• OSS ground circuit open
• OSS ground circuit short to ground
• OSS signal circuit open
• OSS signal circuit short to ground
• Park-neutral switch code present
• PCM defective (OSS signal ckt def)
• Powertrain Control Module defective
• OSS harness intermittent defect
Most likely it's a bad OSS. The OSS is located on the back of the transmission.
Nov 17, 2009 at 5:28 PM
PEAR69
  • 1,482 POSTS
You should use 2002 as the year..65 psi is too high. IMO - fuel injection pressure damper (or the fuel pressure regulator) is faulty..Check and test all he other things that mathiaso mentioned first - if you find the problem it will be cheaper than a regulator..
https://www.2carpros.com/articles/catalytic-converter-replacement
BTW - you still need a cat. converter -- and you should just replace all of the O2 sensors..
Nov 17, 2009 at 5:56 PM
I-SMOGEM
  • 118 POSTS
Prior comment about cleaning a MAF with break cleaner or unknown electronics cleaner is an absolute no! You can't use carburetor cleaner, brake cleaner, throttle body cleaner, alcohol, or simply any cleaner on a MAF sensor, as the residual chemicals in those cleaners can stick and destroy the delicate sensors. Instead, a special MAF sensor cleaner is required and should okay be used.
First, never use MAF cleaner with the engine running or even with the key in the run/on position. This can cause major damage to the sensor if it's still attached to the wiring harness and the sensor wire gets hot. It's best to remove it completely from the vehicle and clean it at a work bench.
Second, never reinstall while it's still wet. It must be thoroughly and completely dry.
I apologize for disagreeing with a comrade... but, please only use a dedicated MAF cleaner.
Oct 23, 2020 at 4:39 AM
