Occassional no start problem. Happens rarely on re-starts after sitting short period of time. And it appears to happen when the air temperature is hot and humid. When it happened I waited an additional 15-30 minutes and it then will start.
Things already done:
fuel pressure key on=55 psi running=50 psi
after running held 50 psi over 5
minutes
cleaned MAF and air temp sensors, air filter is clean, no fault codes present, checked battery connections
The vechicle has had all normal service and runs great. Any thoughts on what to check next?
Thanks for your help!
minutes
Sep 7, 2010 at 10:48 AM
