2001 lincoln navigator
DIMPLES031956
I have problems with my car staying started. It has to be force started once started it dyes unless i hold down on the pedal..I can drive it 20 miles but when I stop it will stall.
Nov 26, 2007 at 5:21 AM
MERLIN2021
  • 17,250 POSTS
You have a vacuum problem...either the Idle air control valve is not working, or a vacuum line is broken. Use a can of spray gumout and spray around the vac lines, when the engine speed changes, you found the leak, if no leaks, change the IAC.
Nov 26, 2007 at 5:40 AM
