2001 Ford Escape Turn signal
2001 FORD ESCAPE
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
BDELMER
  • 6 POSTS
My turn signals are not working - could this be a turn signal relay problem? If so, where is it located?
Oct 28, 2009 at 9:01 AM
RACEFAN966
  • CAR REPAIR CONTRIBUTOR
  • 5,029 POSTS
I would check the electronic flasher module. It is located behind the lower left (drivers) end of the dash. This is what makes the signals flash. Now if they don't even come on at all then also check fuse number 6 should be 10 amp. Let me know what you find.
Dec 1, 2018 at 11:48 AM
BDELMER
  • 6 POSTS
After pulling the fuse and checking it, it was not broken. But later when driving it the turn signals then worked.. so what might be causing this fuse to malfunction?
BDELMER
  • 6 POSTS
so now the turn signals are intermitten... something else must be causing the issue... what do you think? Turn signal relay?
RACEFAN966
  • 5,029 POSTS
I would say check the electronic flasher module which on this car is the turn signal flasher.
BDELMER
  • 6 POSTS
I will look into it... thank you...!
BDELMER
  • 6 POSTS
thanks! ordered part will install myself...!
RACEFAN966
  • 5,029 POSTS
Ok sounds good let me know how it goes.
BDELMER
  • 6 POSTS
got the part, installed it, things are great! THANKS
RACEFAN966
  • 5,029 POSTS
Great glad to hear it and the best thing is you where able to do this yourself and save some labor money. Thanks again and if you need any other help just ask.
