2001 Ford Escape Timing Cover Gasket/Oil Pan Gasket
2001 FORD ESCAPE
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
CLISHER
I recently took my car in for a routine oil chnage. They found an oil leak that requires replacing the Timing Cover Gasket and Oil Pan Gaskett. The cost tehy quoted was $1800. First, does that sound like a reasonable cost? Second, the leak is not major (just a few drops in the garage) how urgent is the repair?
Mar 16, 2010 at 1:04 PM
  • 110,240 POSTS
It sounds really minor. If it isn't leaking but a couple drops per day, I wouldn't be too concerned. Just make the engine oil level stays in the full range.
May 5, 2010 at 3:29 AM
