2001 Ford Escape starter not disengaging
155,465 MILES • 6 CYL • 4WD • AUTOMATIC
ODDJOB626
is there a way to tell if it's the starter or an electrical problem by looking at it and not taking the starter out
Nov 1, 2008 at 7:12 AM
  • 75,988 POSTS
2001 Ford Escape starter not disengaging -Do you mean its continously cranking engine over when you release the key to run or off position-If so test the starter relay and ignition switch
Nov 1, 2008 at 7:57 AM
ODDJOB626
no it's engaging while the key is in the on postion, i will start when i turn key to on postion i dont have to turn to crank and it shuts off when i take the key out
Nov 1, 2008 at 1:33 PM
  • 75,988 POSTS
Have the ignition switch tested-
Nov 2, 2008 at 4:40 AM
