2001 Ford Escape shifting
193,000 MILES • 4 CYL • 2WD • MANUAL
SWEETMIKEB94
More and more frequently I am able to switch gears, usually 3rd or 4th, but the transmission does not engage and when I push the accelerator it revs up but gives no power to the drivetrain. Then I will shift to a lower gear and it engages, then I can switch to the higher gear. What could cause this?
Sep 14, 2009 at 1:13 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Clutch disc worn and slipping takes alot of grip in higher gears. Typical diagnosis slips in high gear.
Sorry time for a new clutch
Thanks for donate
Sep 14, 2009 at 4:35 AM
