Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Escape
Engine
Symptoms
Idle Rough
2001 Ford Escape rough idle
2001 FORD ESCAPE
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
NATE265
MEMBER
1 POST
when cold engine has trouble idling, must put in neutral and give gas to keep it idling. once engine is warm engine runs normally
Jan 28, 2008 at 11:46 AM
BLACKOP555
Experienced Mechanic
Sounds to me like a faulty coolant temperature sensor to me. usually the #1 cause of the problem you described. and usually goes away when worm.
Jan 28, 2008 at 12:28 PM
TODDZ2000
MEMBER
1 POST
I changed to air idle control unit. That did help, but it was still idling low at times.
Then I had the throttle decarb and PVC replaced, still a problem.
I'm taking back to service station.
Jan 31, 2008 at 1:30 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
