2001 Ford Escape rough idle
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
NATE265
when cold engine has trouble idling, must put in neutral and give gas to keep it idling. once engine is warm engine runs normally
Jan 28, 2008 at 11:46 AM
BLACKOP555
  • 10,386 POSTS
Sounds to me like a faulty coolant temperature sensor to me. usually the #1 cause of the problem you described. and usually goes away when worm.
Jan 28, 2008 at 12:28 PM
TODDZ2000
I changed to air idle control unit. That did help, but it was still idling low at times.
Then I had the throttle decarb and PVC replaced, still a problem.
I'm taking back to service station.
Jan 31, 2008 at 1:30 AM
