My Wipers do not work
NASCAR007
Six cylinder four wheel drive automatic
i checked what was wrong because my wipers were not running and making noise and found out that the two rods which connects the motor was broken. What is the best place to get it done or where can i find this parts?
May 12, 2008 at 2:53 PM
MIKE H R
  • 3,094 POSTS
Are the rods broken or have then poped off the pivot arm? Most of the time you will have to remove the wipers off, then remove the cowling. there should be a couple of screws that hold it in place. Then you should be able to get at the wiper arms. If the rods are broken then you can either buy new from dealer or go to a junk yard and get the assembly.
May 13, 2008 at 3:00 AM
