2001 Ford Escape lift gate and rear window won't open
MICHELLETICE65
Electrical problem
2001 Ford Escape Engine Size unknown Front Wheel Drive Automatic 122000 miles
the lift gate and window will not open everytime i try to open them. sometimes it does and sometimes it doesn't. when i click the key fob opener it does not make a "opening" noise like it is not unlocking it?
Mar 2, 2008 at 12:43 AM
AKARICKE
The door lock actuator is bad. I had the exact same problem and found this http://wiki.answers.com/Q/How_do_you_remove_the_lift_gate_door_lock_actuator_on_the_2001_Ford_Escape
Folllowed the directions and worked like a charm.
Jun 27, 2009 at 6:10 PM
