2001 Ford Escape Ignition switch lock
12,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRANDPANORM
Can't get the ignition switch to turn from the lock position. Also steering is locked.
Feb 5, 2009 at 9:29 AM
ZACKMAN
  • 4,202 POSTS
You have put the steering wheel into "locked" mode. Put the key back into the ignition. Turn the steering wheel clock-wise (it will feel tight, that's OK). While turning the wheel, turn the key on. You will get it unlocked. You may need to try it a few times, before you have the "I get it" feel.
Feb 5, 2009 at 12:16 PM
GRANDPANORM
[quote:08eb9527e6="grandpanorm"]Electrical problem
2001 Ford Escape 6 cyl Four Wheel Drive Automatic 120,00 miles
Can't get the ignition switch to turn from the lock position. Also steering is locked.[/quote:08eb9527e6]
Had no luck with the turning the wheel process. In
case someone else should ask, maybe this will work
for them. I just lightly tapped the key head 5 or 6
times with a screwdriver handle. The key then
turned easily.
Feb 6, 2009 at 5:21 AM
