fuel pump reset button
2001 FORD ESCAPE
155,900 MILES • 6 CYL • FWD • AUTOMATIC
SKM23
Where is the fuel pump reset button?
May 3, 2008 at 1:19 AM
This is called the inertia switch and I am attaching the info below and is used to cut the fuel off in the event of an accident or rollover.
However, I suspect you have an issue with fuel pressure or the engine not starting. If you do then here is a guide that will help with checking it to be sure:
Take a look at the info below on this switch and how to replace it.
Please let us know what questions you have. Thanks
Nov 9, 2021 at 11:03 AM
