2001 Ford Escape Engine does not start
164,000 MILES • 6 CYL • 2WD • AUTOMATIC
WENTER
Engine on my 2001 Ford Escape does not start.
My troubleshooting so far:
1) Checked for spark - spark on all 6
2) Checked compression: 185 psi on 4, 195 on another and 215 on another
3) While doing the compression test did not remove fuel pump relay - there was strong gas smell - so I assume fuel pump is working.
4) Checked all fuses - all are ok
What else should I check?
Jul 5, 2010 at 1:00 PM
  • 75,988 POSTS
Check the fuel pressure if its within specs and also if the injectors are pulsing
Jul 5, 2010 at 1:13 PM
