2001 Ford Escape engine coolant
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
AMEROSO
My engine coolant light came on so i put antifreeze in my car and now the light is on all the time. could there be something else wrong with the car?
Feb 12, 2009 at 12:52 AM
F4I_GUY
  • 3,302 POSTS
If the low coolant light is illuminated and the coolant resevior is topped up, then I would look into the coolant sensor.
First try giving it a few taps on the bottle and on the sensor to see if it can turn off the light. if that doesn't work it's a pretty straight forward switch test. Ensure the circuit has no opens and if not, replace the sensor.
Feb 14, 2009 at 4:08 PM
