2001 Ford Escape blinker lights come on when headlamps are
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
KEITH99
The left blinker light stays on when headlamps are turned on but do not work when the blinker switch is activated. The right works fine. Also when the headlamps are off and the left blinker is activated the instrument panel lights flashes along with the blinker but the exterior blinker, front and rear, operates normally. The fuse is okay and there are no other electrical problems
Mar 6, 2008 at 4:34 AM
CHUHI
I have the same problem. Let me know if you find anything. I keep researching myself.
Mar 11, 2009 at 12:56 AM
