I've replaced the spark plugs, fuel filter, engine air filter, intake plenum gasket set, fuel pump on my escape due to the vehicle running rough.
I started getting check engine lights come on P0301 & P0351 codes. I had the ingition coils replaced for #1, #2, and #4. I also had the fuel rails and fuel injectors cleaned in addition to EGR vacuum hoses.
Now they tell me that the ECM is bad and need replacing? Could that be the problem now?
Mar 22, 2010 at 2:50 PM
